Results 1 to 4 of 4
Thread: 90 IDI Air Intake
    Senior Member Sucked In THE BOSS's Avatar
    Nov 2006
    Zanesville, wv
    Default 90 IDI Air Intake
    Ok I have heard many way to get a litle ump out of my diesel well first glow plugs had to be changed so I did that and while undr the hood I decided to try many ideas that I heard and that was to trim the lid of my air filter and that turned bad, first I cut the bell off right at the plastic gromet on the inside off the cover reinstalled the thing the next day temp were low and truck wouldnt start. pluged in, cycled the switch to preheat press acel pedal half way and cranked no detonation repeated this several time with no luck final resorted to either. this went on for aweek till I finally went to a junk yard and got another air filter cover (no problems since).learned my lesson from that one now if i could find out why this thing dies when the high idle drops down n cold start ups
    Come check me out on MySpace at http://www.myspace.com/jratlantic
    1995 Audi A6
    1990 F250 metropolitian w/7.3IDI 4x4 by magnum coach company
    1984 Mazda RX-7 first Gen w/rotory airplane motor( still in storage )
    Default Re: 90 IDI Air Intake
    Dies when the idle drops down, but does it restart ok?
    I had tried a bunch of different mods that I had read online with the older NA diesels and never had the results that anyone else "claimed" either.
    That sucks, sorry to hear that.
    I have seen lots and lots of air intake mods for the 7.3L IDI N/A over the years.
    The best four I have found are
    1) Remove bowl from inside of lid
    2) Remove the small plate in from of the air filter where air comes into the air cleaner
    3) Install HyperMax Cold air intake. Click here
    4) Intall a well oiled K&N with a Well oiled K&N Pre Filter wrap or order a S&B Filter and Install.
    All these other Ideas of cutting holes into the air cleaner are worthless because the allow the engine to suck more hot air into the engine. The goal is to allow the engine to consume as much cold air as possible. More air in and more air out.
    Senior Member Committed ColLonewolf's Avatar
    Feb 2004
    Mine had the soup bowl done as well as the little plate when I got her. At one time it had the Hypermax cowl induction but that was long gone when I got her. Routed a home made ram air with a heavy dryer vent tube. Even has the K&N Filter. Everything works fine but I cannot guarantee anything out of the ordinary.
    89 C-350 Centurion 4X4 (F-350 4door Bronco), W/93 7.3L IDI non-turbo, ZF 5-Speed(LUK)/BW 1356/Dana 60/Sterling 10.25, 3.55, Hypermax Turbo/Intercooler, 3 1/2" Exhaust/Pyro(inop), RDT, 265/75R16 BFG/AT on 16X8 American Racing Wheels 138K and still going strong
    1983 300SD Turbo Diesel, 3.0L Inline 5, 4 Speed Auto, White/Parchment, VDO Boost Gauge, 215/60R15 Bridgestone Potenza RE960AS Pole Positions on 15X7 15 Hole Wheels, Straight Piped, 298K?
  1. Intake Air Temperature Experiment
    By SMOOTH in forum Tech write ups and Installs
    Last Post: 10-31-2010, 09:10 PM
  2. 302 intake tear down
    By sheepman in forum Four Door Bronco, Centurion, Magnum Ect.
    Last Post: 11-25-2009, 01:44 PM
  3. PSD intake spider Thoughts???
    By Traveler in forum Four Door Bronco, Centurion, Magnum Ect.
    Last Post: 11-06-2008, 07:11 PM
  4. Air Intake?
    By Derek in forum Four Door Bronco, Centurion, Magnum Ect.
    Last Post: 07-22-2008, 05:05 PM
  5. '93 turbo intake plenum
    By JohnDeStef in forum Four Door Bronco, Centurion, Magnum Ect.
    Last Post: 01-12-2006, 07:45 AM
